Old 07-06-2022, 06:18 AM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Default question for the sYc hive mind please
While digging, I found a stash of pulleys and came across this one that I've had a long time...
It's identical in dimensions to the famed 3742991 stamped steel SBC SWP HiPo single groove crank pulley... but it's cast iron, and heavy!
It doesn't look like it was made in a HS machine shop one day and it's drilled / balanced like I've seen other GM cast pulleys... it's a deep groove, same as the above referenced one. No markings.
Thoughts? After market, marine, implement, heavy truck, machinery application?...
Thanks in advance,
Anthony
Attachments - The Supercar Registry IMG_0942.jpg IMG_0941.jpg IMG_0940.jpg IMG_0939.jpg
