Old 06-20-2022, 03:25 AM
67ssmn 67ssmn is offline
Default 1967-1969 camaro hurst shifter
comp plus 4 speed shifter, part # 391 4340, nice shifter, tight, shows little use, some MINOR surface rust where handle bolts on, the mount bracket application is unknown, so if you want just shifter it is 75 shipped
Attachments - The Supercar Registry IMG_5873.jpg IMG_5872.jpg IMG_5871.jpg IMG_5870.jpg
Old 06-20-2022, 04:01 AM
Too Many Projects's Avatar
That is quite different than the mount on my '67 Muncie conversion. It looks like it may be for a Saginaw trans.
Mine sits on top of the crossmember mount.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 06-20-2022, 04:11 AM
you are probably correct, if someone does not want bracket i will knock off 20$
