Old 05-29-2022, 05:56 PM
169indy's Avatar
169indy 169indy is offline
Default 1969 Camaro Park/Turn Lights U46
This ad is for: 1 pair of refurbished – used- (original) VERY RARE PERFECT U46 repaired (*Relugged, Refurbished, etc) original park light assemblies for a 1969 Camaro equipped with the U46 Fiber Optic System. These assemblies have been disassembled, cleaned, glass beaded, polished, plated, painted, reassembled and Bench tested. These ARE originals not reproductions. Including the Made in USA stamping on back side and the GUIDE 12 SAE IP69 stamping on the inside of the housing. The assemblies have been carefully disassembled and cleaned and Zinc –Dichromate plated to 'replicate' the as manufactured appearance, you cannot get by purchasing reproductions or by painting. The wiring harness has been cleaned or repaired and preserved, The socket-contacts has been cleaned and tested for proper operation. The Packard series 56 wire female spade terminals have been cleaned or replaced (Properly Crimped). Included are NEW mounting (Like 271172) AMK nuts. 1/4-20unc w/ attached external tooth locking washer. Parking Lamp 916911, Wire Blk Turn +12vdc, Wire Ppl Park +12vdc, Housing -12vdc. (Bulbs NOT supplied) Proof of operation documented - photo attached to each lamp assy.
These ARE used parts that have been cosmetically restored . Why settle for repops, when the hard work has been done for you. Easy to swap out your tarnished worn assemblies & renew a very visible item on your vehicle. The U46 Grommet is unique and not reproduced. The wiring sleeves and housing finishes are PERFECT. The Housings are NOT some Drilled Fake. These are scarce and I doubt I will ever find additional cores. "Before" photo added for clarity.
Shipping size is (appx) 11” x 9” x 6” @ 1.5lbs
Pricing options:
$600 outright
$300 WITH trade in of equivalent factory cores in acceptable condition.
USD plus shipping from ZIP 98314 (WA)
Paypal "Friends & Family"
PM me if any ?'s
Attached Images (Set-U46)
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Attachments - The Supercar Registry 100_7526.jpg 100_7525.jpg 100_7524.jpg 100_7523.jpg
