Old 03-24-2022, 01:05 AM
X22SS X22SS is offline
Default 70-73 Big Block 396 454 power steering pumps
Up for sale are 5, five, 70-73 style Big Block 396 402 454 power steering pumps. All 5 have the correct return line for Chevelle Camaro Nova. The cans are in good condition, not all beat up from adjusting the belt but may have small dings.
Pump #1
Pump #2
Pump #3
pumps #1, #2, and #3 have the early adjuster with out the square drive adjustment boss, 3770509 single groove pulleys and 2 original cradle bracket to block mounting bolts. Bracket part numbers are 3967422 cradle and 3967420 adjuster. Brackets have some pitting.
Pump #4 has a 3941107 double groove pulley for AC, no mounting bolts
Pump #5 is a remanufactured pump and comes with everything pictured, all mounting hardware including the block mounting bolts, GM 3770509 single groove pulley, original pulley nut and cap. Early adjuster with out the square drive adjustment boss. Bracket part numbers are 3967422 cradle and 3967420 adjuster. Paint is not that good, the can neck has been brass sealed. Can has belt tightening dent/dings.
I did a "shade tree" pump check on pumps 1-4. I put fluid in the pump and spun the pulley by hand and got a good 6 foot shot of fluid out. I can't guarantee leaks or how well they will work.
$150 each
Pump #5 $175
All prices are plus shipping cost, send me your zip code for shipping cost.
Paypal or MO/check is fine.
Attachments - The Supercar Registry 101_8788 (2).jpg 101_8784 (2).jpg 101_8783 (2).jpg 101_8782 (2).jpg
