Old 03-15-2022, 07:29 PM
jbtech's Avatar
jbtech jbtech is offline
Default 1967 Camaro L78 Parts List
Hello everyone. I'm slowly hoarding parts for my 04D 1967 Camaro 396 L78. This post will be modified as the needs change.
I like the idea of driving the car as is until all the parts are found and God willing the original engine is in my garage before beginning a correct restoration.
Parts Wanted:
RH A Pillar Molding (Bright) 7657638
Positive Battery Cable 6289139 ZM
Negative Battery Cable 2987212 XP
Window cranks 2 needed 7680653
Standard Seat Belts + Hardware
Decklid Dated T14, T15, or T16
Trunk Mat
Speedometer Cable Clips
Assembly line 1967 Battery Tray
Radio Block off Cover 3893845
Down the line:
Radiator
Shroud
WT Stamped Master Cylinder 5460346 Dated near Booster and Valve (82, 75)
Dated Gas Tank
Original Fuel Sending Unit
NOS GM Control Arm Bushings
NOS GM Body Mount Cushions
Fan Clutch
Shocks
Original Mono Leaf Springs
Parts Found:
September '66 4.56 Ring and Pinion
No Date 174 Carrier
7C Voltage Regulator
66M Heater Core
Black Surrey Sun Visors
67 Survivor Valve Covers
1100693 Alt
3844100AK pulley
SS Hood Dated week 14
SS Hood Louvers
Dash Pad
LH A Pillar Molding 7657639
SS Gas Cap
SS Emblems
Parts Pending Found:
Original GM Interior panels + Arm Rests
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
SuperNovaSS (03-16-2022)
