Old 02-09-2022, 09:09 PM
Default 1967-68 only - Firestone Wide Oval F70-14
I need one more real 1967 Firestone Wide Oval F70-14 white-stripe tire. These are the version that have the writing in close to the wheel, and the stripe out close to the pavement. A pic of two of them is attached. These are not reproduced. The repro has the stripe close to the wheel and the writing outboard of the sidewall center (I believe that was the 1969+ version).
Second pic attached (on a Mustang spare wheel) is the "late" 67 to early 68 version, with the stripe moved inboard slightly. Then there was another version after that in 68 with the stripe moved inboard even farther - so far that it is actually cut into the VA in the word "OVAL". I really need the earliest version shown in the first pic, but I would take any of them. Beggars can't be choosers!
I could also use some red stripes of this same tire too, if anyone has any.
Thanks! Jeff
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Attachments - The Supercar Registry Late 67 Firestone F70.jpg 67 Firestone F70.jpeg
Tags
1967, 1968, f70, firestone
