Old 02-06-2022, 03:52 PM
Ls648410's Avatar
Ls648410 Ls648410 is offline
Default 1970 Chevelle SS LS5 L34 U14 Optional Gauge Package 5500 Tach & Wiring Harness
-1970 Only with "Green" letters and numbers 5500 Red Line U14 optional gauges for L34 396 350 HP and LS5 454 360 HP, #67 on the build sheet INST. CLUSTER was noted "GK" for this option, the original "GK" label with GM part # 6491966 is still attached. Comes with the rear circuit board and twist in light inserts with bulbs. Over all in excellent shape but nothing has been tested so selling "AS IS". Clock has pole extension and knob missing. Front lens has never been removed as the new owner can decide to clean it or not. $750 USD plus $25 Shipping.
-Original Interior Wiring harness that came from the same dash assembly as the cluster gauges, NO stripped wires and complete, only the Dimmer High Beam plug has a tab snapped off on one side but will be functional and you can not see this under the carpet anyways, the front of the fuse panel could use a clean up to get rid of the small amount of surface rust with evaporust or just a small wire brush IMO. $500 USD plus $18 Shipping
Paypal "Friends"
I included photos of the complete front dash assembly that the above gauge package and wiring harness came from originally. I do also have a few extra Dash pads for $400 each plus $50 Shipping, I have NO uncracked Dash housings.
TOM
Attachments - The Supercar Registry Gauges 5.jpg Gauges 4.jpg Gauges 3.jpg Gauges 2.jpg
Old 05-25-2022, 10:05 PM
Ls648410's Avatar
Sold out !!
70 SS 454 LS6 Forest Green/White Interior M22 4.10
70 SS 454 LS6 Black Cherry/Black Interior Pro Touring
