Old 01-22-2022, 03:32 PM
drdave69 drdave69 is offline
Default Leaky fuel line
I sent my qjet to Eric for rebuild and needed to replace the fuel pump to carb after I got it back. I installed the new line and is leaking at the fuel pump fitting. I refitted it two more times and it is still leaking. I lifted the front of the car to try to get the fuel from flowing to the fuel pump for now. I have not started the engine yet with the new line (for obvious reasons) so I don’t know if it will be leaking at the carb. It was leaking at carb with the prior line and that is why I bought a new line.
What is the best way to solve this issue? I have considered getting a stainless flex line with AN fittings if that will fix this problem.
This is on my 70 Monte Carlo with LS5 454.
Dave
1987 Grand National
Old 01-22-2022, 04:05 PM
Too Many Projects's Avatar
Original fuel pump or aftermarket ? Many aftermarket needed an adapter for the flare on the hard line. A flare line will thread into an iron pipe thread, but obviously not seal.
I've run across over the counter A/C pumps that needed that adapter also.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 01-22-2022, 04:09 PM
napa68's Avatar
napa68 napa68 is offline
Something like this works wonders
Tim
https://www.amazon.com/FASPARTS-Copp.../dp/B017L50CKY
The Following 3 Users Say Thank You to napa68 For This Useful Post:
169indy (01-22-2022), Too Many Projects (01-22-2022), YenkoYS-199Stinger (02-01-2022)
Old 01-22-2022, 04:31 PM
tjs44 tjs44 is offline
I started using the AC copper flair gaskets about 10 years ago and EVERY engine I work on gets them.The are a life saver .Tom
The Following 2 Users Say Thank You to tjs44 For This Useful Post:
169indy (01-22-2022), jerry455 (01-24-2022)
Old 01-22-2022, 05:18 PM
Tim
Cool !! I never knew of these either ! What a great source of information.
I avoid adding to Bozos' considerable fortune, so found them on FASPARTS website for $2.50 each. I ordered 6 and even with shipping the cost comes out to $21.69. About half the cost of 6 with free shipping on Amazon...
https://fasparts.com/store/sae45-59-6.html
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Old 01-22-2022, 05:22 PM
Just add a little grease around the threads of the new line, that should do it. Had the same problem with a new line, but at the carb end. So far, not a leak in four years. I used wheel bearing grease.
Old 01-22-2022, 08:01 PM
Diamond_Don Diamond_Don is offline
Mr. Nickey Nova has suggested a easy solution that I tried out. I had a fuel leak issue at the fuel pump and asked for tips/solutions on this forum. A member at that time suggested the grease on the threads technique. Such a simple fix and I wasn't expecting miracles, but that's what it turned out to be. At least a year later and I am not experiencing leaks !
Old 01-22-2022, 11:47 PM
Thanks. I ordered 6 of the copper washers but will try the wheel bearing grease first. I would have never known about either of these solutions. That is why I posted this dilemma here first for the knowledge of the people here.
Dave
1987 Grand National
The Following User Says Thank You to drdave69 For This Useful Post:
parkbrau (01-24-2022)
Old 02-01-2022, 05:10 PM
firstgenaddict's Avatar
I find that the double flares done by a hydraulic flaring tool are not as consistent in the mating surface as the ones using a tool that spins the end into the flare.
SO
I have found that lightly snugging the nut and then spinning the tube around a few times (lapping the flares together) then light tightening and repeating the spinning of the flare will lap the two together and alleviate leaks- it works especially well on problem stainless flares.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Old 02-01-2022, 08:14 PM
KevinW KevinW is offline
I used a small piece of copper sheet and made my own washer and it worked fine. Also, the alignment has to be perfect and tighten 5 or 6 times to work the flare
69 327 convertible (driver)
