Old 01-10-2022, 08:49 PM
martyb's Avatar
martyb martyb is offline
Default Fuel
So I have no gas stations near me that sell high octane, and out here in AZ our best fuel is 91 octane. What’s everyone doing for these older cars that need leaded high octane fuel? It’s an original LS6 with 11:25 compression. I don’t race it or drive it hard, but when I do jump on it every once in a while I can hear a little knock. Currently use lead additive and Torco, but not sold on that solution.
1970 LS6 Chevelle
1998 Viper GTS
Old 01-10-2022, 08:57 PM
dvss1 dvss1 is offline
If you have a small airport by you, you could possibly buy it from them. That's what i do here in illinois.
----Get yourself a couple of 5 gallon cans of 110 octane racing fuel. When the tank is down about 5 gallons go ahead and give it 5. That should be enough. Then when you are down 10 gallons pour in the second 5 and take it back to full with 91. Unless you are driving every day this should hold you a good long time. Then repeat!
----I don't know about you but depending on where you live there can be all kinds of additives added to av-gas. Personally, I have had bad reactions with it, but others haven't. Your choice!......Bill S
60sStuff (01-11-2022), Woj (01-11-2022)
Old 01-10-2022, 09:01 PM
martyb's Avatar
You just fill 5 gallon cans or do you fill the car at the airport?
1970 LS6 Chevelle
1998 Viper GTS
Old 01-10-2022, 09:05 PM
See if there are any drag racers living around you. Maybe you can ask them or order your fuel through them?
Paul
Old 01-10-2022, 09:17 PM
----There are speed shops in Phoenix that will sell you 110 octane!......Bill S
Old 01-10-2022, 09:18 PM
TimG TimG is offline
Never fill a licensed road vehicle at the airport. If authorities see you they could fine you for avoiding highway taxes. Much like dyed diesel being found in licensed trucks. Always give priority to the airplanes if you have a gas can. Cloudy rainy days are always low traffic days at airports.
Old 01-10-2022, 09:29 PM
I buy Sunoco 110 by the 5 gal pails and mix it 50/50 with 89 pump gas. I am hoping it nets me around 101/102 but has been working great so far. Unfortunately, it went from $10.34 per gal early last year to $16 gal this year!
John (01-11-2022)
Old 01-10-2022, 09:30 PM
The way to do it is to bring 5-gallon gas can and use that. Never try to fill a car directly at an airport. The self serve pump is usually by the edge of the tarmac and you can just walk up and use your credit card right at the machine. We have a couple local commuter airports within 10 miles of my house. They have the 100 octane "low lead' which the old cars seem to love. A lot of guys also use it for gas-powered landscaping tools since the ethanol mixed fuel is really bad on them.
As for price, it is usually only around a buck more a gallon than whatever 93 octane fuel is going for at the local gas station that day.
Old 01-10-2022, 09:41 PM
seventieshow seventieshow is offline
This is a bit dated but most of these places are still around.
http://azmustangs.com/racegas.htm
Some airports won't sell gas to walk ins, some will. The smaller the airport the better. 100LL avgas works well in old cars but will eventually be phased out.
