Old 01-02-2022, 06:48 PM
AnthonyS's Avatar
Yenko Advertising Member
Default cheap 772 fan
Hi Gang, as the title says, a cheap alternative to the often expensive 772 fan.
It's a Genuine 3947772 fan, but dated C74 and at some point, a previous owner wanted it to be a fixed blade fan and welded the clutch flange to the fan hub...?! Anyway, a subsequent owner then tried to free the two pieces and got as far as cutting them apart; it still won't freewheel. Clutch still seems to have a high viscosity.
Anyway, here's a real 772 fan and clutch for a driver or flipper - it's got the look, just not the date and will need a little clean up which is likely not a big deal for most here reading this.
$50 PPFF plus shipping.
Cheers all,
Anthony
Attachments - The Supercar Registry IMG_5727.jpg IMG_5726.jpg IMG_5725.jpg IMG_5724.jpg
Old 01-02-2022, 09:11 PM
Too Many Projects's Avatar
Looking at the welds from an old arc welder, I'd be amazed if there was any fluid left in that hub. The tension may well be dry bearings sticking together...
I'm interested in using the fan with a new hub. Do you still have my address in plain view to get a shipping quote...
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
