Old 11-26-2021, 12:07 PM
69VN's Avatar
69VN 69VN is offline
Default Muncie Transmission Tag Identification
Trying to confirm the transmission tag on a 1969 Camaro SS350
M20 4spd. I've seen the numbers 3946797 for RPO M20. Could
anyone confirm that this is correct? Thanks in advance.
Sal
Old 11-26-2021, 12:46 PM
X66 714's Avatar
X66 714 X66 714 is online now
Here's a thread I found on CRG. There might be an updated list...Joe
http://www.camaros.org/forum/index.p...6976#msg146976
Old 11-26-2021, 02:09 PM
KevinW KevinW is offline
So the list in that post is from the AIM of course, so you have to assume the part numbers were based on the "standard" rear gear ratio (as well as the actual trans model).
I think the "standard" rear gear for a manual SS/LM1 Camaro (3950356 - L48, L34, L35 & LM1 (assume Muncie M-20) was BS 3:31. Which explains the grouped engines with one trans number.
Of course if you ordered a non-standard rear gear, the trans model may change
Sal, with your SS350 BS 3.31 gear I think you need the 3950356 tag. I have an SS 350 with BS as well and need the same tag
69 327 convertible (driver)
Old 11-26-2021, 05:59 PM
William William is offline
From the 1969 power train chart:
LM1 std axle w/4-speed was 3.31. 3.07, 3.55 and 3.73 optional.
L48 std axle w/4-speed was 3.31. 3.07, 3.55, 3.73 and 4.10 [exc. ac] optional.
L35 std axle w/4-speed was 3.07. 2.73 and 3.31 optional.
L34 std axle w/M20 4-speed w/o ac was 3.31. 3.07, 3.55, 3.73 optional.
L34 std axle w/M20 4-speed w/ac was 3.07. 2.73, 3.31, 3.73 optional.
L34 std axle w/M21 4-speed was 3.31. 3.55, 3.73 and 4.10 [ex.ac] optional.
Old 11-27-2021, 11:08 AM
69VN's Avatar
Hi guys thanks again for all the info. I saw that reproduction tags were available
on ebay thru The Parts Place. Unfortunately #3950356 was NOT available on their
ebay page. Yes ebay does have original tags but I prefer a clean new one. I sent
the parts place an email to see if their vendor can provide one. The embossed font
numbers on the originals appear to be more bold than the reproduction tags, but the
conditions of them aren't great.
Sal
Old 11-27-2021, 08:27 PM
I have 2 but one but the best one has some pitting and the other one is rusted thru.
Good luck with the search.
Martin
Martin Foltz
68 Camaro SS-396
Old 11-28-2021, 01:36 AM
crash crash is offline
E-mail me if you are still looking for a 3950356 tag, I only have original.
I also have 3946797,798 and a bunch of others.
Thanks... Crash [email protected]
