Old 11-19-2021, 09:37 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Default 1965 HURST wheels - full set of 4 original matched rims
Hi Gang, often, I used the lead off of "rare part..."
But with these, I have no qualms at all calling these hard to find!
A matched set of 4 original, famous HURST wheels - aluminum center sections, steel hoops, trim rings and caps! All off the same 1965 Mustang that were installed by the dealer after being purchased by the ordering buyer.
These were just recently removed from that 1965 Mustang GT in favor of chrome styled wheels during a factory restoration. Apparently the original owner Day 2-ed this car on Day 1.
The story I got was that Dorothy was a newly minted college grad and she and her Dad went to order her a shiny new Mustang. And Dad was apparently a cool cat as he sprung for the GT and a set of shiny mags for her ride. She kept the car throughout her adult life and her heirs recently sold it and it is undergoing a factory restoration to stock. As I understand it, the wheels were the only deviation from stock over the years. She never completely stopped driving the car, it had never sat as I was told but she may've driven it longer into her retirement than was safe - for the fenders, garage doors and trim rings... It was a cool story. A lifelong SoCal car.
Anyway, here they are as I found them, any blue goo you see in the photos (and I will upload a lot for the whole story) is a polishing compound that the resto shop helper / detailer took to the center sections to try and clean them up. I haven't touched them except to look for casting marks / numbers.
The trim rings are curb scuffed for sure and would need restoring - I'm not sure how they are removed, but they appear to have similar looking clips to our beloved rally wheel trim rings... and they look to go around the five spokes - I tried to show the detail in the photos. They are beat from being curbed. But likely restorable / rechrome-able.
The aluminum is not hardly corroded at all and will certainly clean up very well - there's none of that typical two-metal corrosion at the hub where they mounted. The caps are pitted, a couple more than the others.
They are 14" diameter of course, and likely 6" wide but I haven't dismounted Dot's last set of white walls she had installed years ago to confirm, nor do I know what the inside / bead looks like, but I have no doubt these are perfect inside.
I haven't washed them or tried to remove the road debris or brake dust or grim, just looked for markings on the inside.
They appear to be stamped 4 C 1 A 9
They have the HURST logo casting along with HARVEY Aluminum, the manufacturer, I presume.
They are Ford 5 on 4 1/2 or 5X4.5 bolt pattern MOPAR & AMC too maybe?
Original wheel weights are on there - including a MICRO 1oz wing weight
The original DILL 627 valve stem caps are all present too.
I received 18 lug nuts, two were lost in the trunk I was told and the four Gorilla wheel locks that she installed in the 80s after apparently too much interest in the wheels was shown by the neighborhood riffraff - her words supposedly.
Anyway, not much more can be said about these - but we're all sure of how rare it is to come across a full set and I'm going to assume the 4.5" pattern is harder to find, if not less desirable though...
If you'd like to picture how they'd look on a Mustang, Google "TASCA 505 Mustang"
anyway, $3500 as they are - once paid for I will dismount and discard the tires and box them up - any shipping & insurance will be extra.
Local pick / meet up certainly welcome of course.
Thanks everyone, enjoy the show in Chicago!
Anthony
Attachments - The Supercar Registry RCSJ0026.jpg IMG_2602.jpg IMG_2601.jpg IMG_2600.jpg
