Old 11-01-2021, 09:55 AM
3X24SPD 3X24SPD is offline
Default 15X7 Centerline Auto Drag
Hi Folks, looking for a pair of 15X7 Centerline Auto Drags, 5X4.75. I'm looking for a pair with 4.5-5" of backspacing. Thanks
Old 11-01-2021, 04:48 PM
I don't think you will find a 4.5 inch back space, or a 4.25", which is what I looked for when I bought a pair for my 69 Z.
I ended up buying 5" back space, and use a 3/8 spacer to keep it from rubbing.
I bought mine new. But I don't think they make the 5" back space any longer.
There is a used pair on ebay.
https://www.ebay.com/itm/38436818256...kAAOSw66RhMNVe
And despite no one making a hub centric ring for them, you will want to run rings. You can have them made.
Old 11-01-2021, 05:47 PM
Thanks Lynn. I've actually been watching that set for quite a while- many months. They haven't sold because he's looking for a whole lot more than I personally think they're worth (IMHO).
If he was a little more reasonable in his price, I would definitely grab them and run a spacer.
I bought a nice pair of 15X7s with 3.5 BS locally at a swap meet about a month ago- mounted up some 245/60s. They do fit, but they're not working for me with the back spacing compared to the 15X8.5' rears- so I took them back off.
I am looking to swap out the current 15X4 front runners.
The Following User Says Thank You to 3X24SPD For This Useful Post:
NorCam (11-03-2021)
Old 11-01-2021, 10:46 PM
I also don't believe Centerline is still offering polished Auto Drag wheels in 15 inch; only satin finish.
I bought mine around 2012, but there have been a lot of changes.
I am pretty sure they used to offer 15x7 with 4.25 back spacing, many years ago.
I found a killer deal on a set of very early satin Auto Drags, 15 x 10 and 15 x 7 for the El Camino on CL. They are the ones with dual bolt pattern 4.5 and 4.75...not varilug, two sets of holes drilled) and designed to use beveled lug nuts, all covered by a small screw-on hub cap. Not a scratch on them. Paid $300 for the set, and they had a set of BF Goodrich tires that still held air. I wouldn't drive on them, but they worked great until I got some new tires.
I would watch CL for a set. Old guys like us are dying left and right, and their kids normally don't give a crap about this stuff. So, off to CL they go.
Old 11-02-2021, 01:23 AM
70LS6454 70LS6454 is offline
Those 15x4’s look good on there
Old 11-02-2021, 11:05 AM
Thanks. I'm not looking to get rid of the 15X4's- just swap them out occasionally. They handle pretty good for a narrow tire, but they're not the best thing to take up through the sweepers up in the mountains. You'll be happy to know there is a LS6 454 under the hood of that car (with a Victor, 1050 Dominator, and a 250 HP nitrous plate- hence the hood).
NorCam (11-03-2021)
Old 11-03-2021, 04:19 AM
NorCam's Avatar
NorCam NorCam is offline
Sounds like a mit full. Where are you located that you have mountain twisties?
Old 11-03-2021, 10:10 AM
NH
Old 12-13-2021, 10:20 PM
Still looking for a pair of 15X7 Centerline Auto Drags with 5" backspacing.
In case any of you guys run across a set. Thanks
Old 12-13-2021, 11:08 PM
I thought I read a few years back that Centerline shut down. Something about not being able to keep up with environmental standards.
Did someone buy them out and continue manufacturing Centeline wheels? There are lots of new ones for sale in ebay and I have a hard time believing it is all old stock.
