Old 10-29-2021, 10:06 PM
Default 1967 L78 396/375HP Holley List 3910 Carb and 1111170 Distributor
This carb and distributor recently came out of an estate and both appear to have come off engine(s) very early in life. Based on the dates and similar condition, I imagine these came off the same engine but that is just speculation.
The parts are as described below:
Carburetor:
The choke tower on this carb is stamped as follows: 3916143 CT List 3910 762. The 3916143 CT is the GM number. The List 3910 is the Holley part number. The 762 is the date code. The date decodes as the 2nd week of June, 1967. The carb is totally complete including choke parts. The original coloring/plating is very nice. The carb still has cork gaskets which are likely original to the carb. There are no breaks, repairs, or modifications to this carb.
SOLD
I also have the original fuel line and air cleaner stud off this carb that I can make available to the buyer.
Distributor:
This distributor is a very clean original. It is stamped 1111170 7E26(the 6 is very faint but exists). The 1111170 distributor was used on 1967 L78 396/375HP, L72 427/425HP, and 427/385HP engines. It was also used on 1968 L78 and L72 engines. The date decodes as May 26th, 1967. The vacuum advance is stamped MS 360 12 and moves the points plate as it should when vacuum is applied. The mechanical advance cam is stamped 732 CCW. The distributor spins smoothly with no excessive slop or binding. This is a very nice original distributor.
SOLD
Attachments - The Supercar Registry PA290808.JPG PA290807.JPG PA290806.JPG PA290802.JPG
Old 10-29-2021, 11:21 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
Default Nice
Nice pieces, hard to come by.
Richard
Richard
1967 Camaro SS 396/375 4K
The Following User Says Thank You to 1967 4K For This Useful Post:
SuperNovaSS (10-29-2021)
Old 10-30-2021, 12:09 AM
Sold pending payment.
