Old 09-14-2021, 03:55 AM
firstgenaddict's Avatar
Default 67 Elco L78 Deepwater over bright blue.
Jeff Helms' car - these are photos from the AACA Spring Charlotte meet- he got his First junior there and this past weekend at the AACA Fall National meet he got his First Senior-
You won't find a better restored car or more attention paid to details than Jeff... we talked for a while at Charlotte and then again for a while in Greenville, he pulled me aside and said, you will appreciate this and pointed out the runs in the black paint on the rad support from being dipped etc. Also I noted correct wiper bottle screw caps.
He also had door panels made the way there were done by GM. They have blocks of fiber board glued into the positions of the raised areas and then the "actual surface" is stretched down and thermally bonded in low points, creating sharp distinct breaks VS raising areas by filling the void with foam... drag your fingers across an original and they go thump thump thump. drag them across Jeff's... same thing thump thump thump. I think he said a year to get the pair done.
Could a moderator move this to the L78 Forums...
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
Last edited by firstgenaddict; 09-14-2021 at 04:17 AM. Reason: Request to move to L78 forums.
The Following 9 Users Say Thank You to firstgenaddict For This Useful Post:
bbbentley (09-14-2021), big gear head (09-14-2021), napa68 (09-14-2021), olredalert (09-14-2021), PeteLeathersac (09-14-2021), RPOLS3 (09-14-2021), scuncio (09-14-2021), Woodrock (09-14-2021), Xplantdad (09-14-2021)
Attachments - The Supercar Registry 67L78elco_tailgatel.jpg 67L78elco_pass_rear_3_4.jpg 67L78elco_pass_rear stowage detail.jpg 67L78elco_pass_front_doorpanel_detail.jpg
