Old 09-07-2021, 08:18 PM
Default Radiator Wanted - 67-68 Camaro 327 or 350, automatic with A/C
I need an original radiator for 67 or 68 Camaro with 327 or 350, automatic trans, and Air Conditioning. This is the oddball radiator that had small block sized tanks but a 23" wide core (so same width left to right as a big block).
Per CRG the tank codes are OG (right) and IH (left), and the broadcast code (on the square tag, if it is still there) is UK, and part number 3010181.
Will take any condition, as long as both tanks and mounting brackets are there and usable.
If you happen to have more than one, tank dates of H, J, K or L (August to November) would be really great. But beggars can't be choosers so I'll take whatever I can get!
Thanks!
Jeff Helms
65 Z16 Survivor
65 Z16 drag car
66 Chevelle L78 unrestored
67 Chevelle L78 unrestored
67 Camaro SS350 Survivor
Old 09-07-2021, 09:05 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Yenko Advertising Member
Hi Jeff.
FYI: https://www.yenko.net/forum/showthread.php?t=168467
Anthony
Old 09-07-2021, 11:05 PM
Hey Jeff,
I have several available.
Selling both original OG Dated "K" (November)and IH Tanks with the original ZC Tag $250.00
67 / 68 Camaro Right Side (OG)Tank Usage:
L30 (327/275hp) with V01 (Heavy Duty Radiator) or C60 (Air Conditioning)
L48 (350 / 300 hp) with V01 (Heavy Duty Radiator) or C60 (Air Conditioning)
69 Camaro Right Side (OG)Tank Usage:
LF7 auto w/ (Heavy Duty Radiator) or C60 (Air Conditioning)
Engine, 327ci, 210hp, 2bbl V-8 (replaced with 307 1/1/69)
L14 auto w/ (Heavy Duty Radiator) or C60 (Air Conditioning)
Engine, 307ci, 200hp, 2bbl V-8 (replaced LF7 1/1/69)
Left Side Tank IH 67-69 small block or 6cyl
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
69 RS/Z28 Maroon JL8
66 Corvette Ermine White L75
