Hello, All
Another nick knack page. Starting left from the first photo: 1966-67 Chevelle/El Camino dash molding strip screws (8) and clips (5) and misc. dash screws and clip below them- $18. AC hose clamps- Ideal markings (2) Ideal Hy gear markings (3) Murry gold seal markings (1) - $5. Ea. 1968-69 Chevelle taillight bucket to lens bezel screws. Hard to find. (6) - $12. 1970-71 Chevelle/El Camino/Monte dash pad clips - $10. 1970-71 Chevelle/El Camino/Monte dash turn signal, high beam, and brake lamp lenses. I don’t know if these are being reproduced yet- $20. For all. Transmission speedo gear holder retainer and bolt. Super clean.- $10. Over the counter electric trunk lid switch and bezel-$15. GM Holley carb fuel line nut – on the hex nut area, two spots have some slightly rounded corners (not bad) on the two flat areas, same thing. Great driver quality. $15. “T’s” – I want to say these are 5/16ths, some have BMC markings. All are original (5). (1) straight one $5. EA. --ALL SOLD-- 1968-69 Chevelle lower inner rear quarter panel drain plug- nice, hard to find - $15. Brown wire harness ends (2) - $2. Ea. Transmission lever retaining holder, wavy washer, and bolt - $15. Small block Chevy block oil line fitting w/ weather head markings, super nice - $15. Early seat belt return spring w/ MOD.100B-W markings, super nice shape - $20. Steering column shaft bolts and nuts, set of two. (1) upper- w/ circle and F in the middle with 5 lines.(1) lower NL markings. Both have the correct raised dot lock nuts. Nice shape- $ 10. For the pair. 1970-71 Chevelle/El Camino/Monte speedo cable (@ dash pod) retaining clip- $5. Early BB Chevy right side lower front spark plug wire holder (#2 cylinder) still has some of the vulcanizing material on it. Super hard to find- $15. Assembly line “square end” hose clamps, (2) power booster hose SOLD (2) 3/8 fuel line. Nice shape, unrestored - $10. Ea. ----ALL HAVE BEEN SOLD---- Whitock tower clamps- 1 1/16 no date code (2). 1 1/16 w/ 2/71code (1)SOLD. 1 1/16 w/ 3/72 date code (1)SOLD. 1 1/14 no date code (4). # 7 Water pump clamps (2). #23 Power steering hose clamp (1). All are in good shape, either run them the way they are or great ones to be re plated- $10. Ea. 1969-72 BB Chevy power steering pump stud w/ X markings on both ends - $20. 3/8 stud w/ X markings on both ends - $5..----- SOLD ---- 1970-71 Chevelle/El Camino/Monte dash retainers for heater control (2) - $5. For the pair. Brake pedal pins and retaining clip. (1) with RBW markings. (1) with L in a circle. All the clips have AWT markings, including the (1) extra clip. - $10. Ea. $5. For the extra clip. TH 350 and 400 shifter cable stud and clip - $10. Emergency brake retaining cable clip @ pedal w/ AWT markings (2). - $2. EA. 1970-71 Chevelle/El Camino/Monte ash tray bump stops (4) and one screw. - $5. Pair. Chevrolet bench seat plastic side cover retaining clips (3) extremely hard to find - $20. For all. Rear diff E-brake cables retaining clips (8) - $1 Ea. 1970-71 Chevelle/El Camino/Monte dash E-brake lever bushing (2) - $1. Ea. 1970-71 Chevelle/El Camino/Monte dash E-brake lever to E-brake pedal clips (3) - $5. Ea. Door side mirror bracket - $5. 1970 Chevelle/ Chevelle/El Camino/Monte headlight screws nuts and grille screws and nuts Various clips - $15. For all. 1970 Chevelle/ Chevelle/El Camino horn wire clips-two sets - $15. Pair. Carb retaining clip - $5. Early BB Chevy water pump bolt set (could be re pop, not sure) - $5. NOS 4-speed bell crank push rod- A little rusty from sitting around - $ 20. ---- SOLD--- Can send better photos on request. Open to offers and package deals. Shipping- depending on the items, some I may be able to get into an envelope and some will need to be shipped USPS flat rate bubble envelope @ $8.75to the lower 48 states. Payment to be made by pay pal via friends and family please.
Cranberry red 1970 L-S6 hardtop Last edited by Geoff Padgett; 09-14-2021 at 07:58 PM. Reason: sold some |
Good morning Jeff,
I will take the Clutch rod if still available. Get me a total shipped to 53511 Thanks, Joe |
PM sent
Joe |
Ad updated 8/20/21-- some stuff sold pending payment. Please see list for details.
Cranberry red 1970 L-S6 hardtop |
Ad updated 9/1/2021 and Bump
Ad updated, some prices dropped and bump
