Old 06-13-2021, 07:23 PM
Gonzo1717 Gonzo1717 is offline
Default 3923289-DZ 8A3 Date Code Restored Main Body
Selling a 3923289-DZ 8A3 date code restored main body. I purchased this main body which had the back of the choke horn milled off. I found a donor carb and had the choke horn professionally repaired. The complete carburetor was sent to Eric Jackson at Vintage Musclecar Parts for restoration, which turned out absolutely phenomenal. Unfortunately, the plating process wouldn’t take on the weld repair area. This had no effect on functionality and is purely aesthetic (I can provide a link to a video of the carb on a running engine if needed) I have since located another 8A3 coded main body and had Eric restore that one therefore, this main body is no longer needed.
Seeing as I searched two years before I found an 8A3 coded carb, I’m assuming this date code is somewhat hard to find.
200 plus shipping
Thanks!
Attachments - The Supercar Registry 594E966B-8790-4E80-B92C-744F2714F34D.jpg 537C4F00-6DD4-4727-B9C9-BD1A9BE75317.jpg 49FA60A9-DF3B-4FE1-A115-C834DDF6C5CB.jpg 44A9A369-7DB4-4A3C-BA76-293371ED2B9E.jpg
