Old 06-03-2021, 06:20 PM
X66 714's Avatar
X66 714 X66 714 is offline
Default Camaro disc brake change out
Anybody have spindles, caliper mounts, dust shields & calipers that can be used on a first gen Camaro. No repop stuff please. I got a guy looking. I can send him your way. Thank you, Joe
Old 06-03-2021, 06:22 PM
67 Nova Boy's Avatar
67-68 are 4 piston...69 is single piston. What year are you searching for Joe?
Dave
67 Nova Boy
Old 06-03-2021, 06:48 PM
X66 714's Avatar
I think he wants the 1969 version. He can use his original steering knuckles if he needs to...Joe
Old 06-03-2021, 07:18 PM
jl8z28 jl8z28 is offline
Yenko Premier Member
I have some backing plates
The Following User Says Thank You to jl8z28 For This Useful Post:
X66 714 (06-03-2021)
Old 06-03-2021, 08:13 PM
WorkinProgress WorkinProgress is offline
Joe,
When you say steering knuckles are you referring to steering arms?
Disc brake spindles are different than drum brake spindles.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
Old 06-03-2021, 08:39 PM
X66 714's Avatar
Yes. Steering arms. All has to be disc brake. Thanks, Joe
Old 06-03-2021, 09:00 PM
big gear head's Avatar
I used my disc brake arms on drum brake spindles. As far as I know the only difference between drum and disc brake spindles is the length of the boss for the upper bolt.
Freddie
Old 06-03-2021, 09:05 PM
scott s scott s is offline
i have a set of spindles and orig 2 piece rotors also..
The Following User Says Thank You to scott s For This Useful Post:
Old 06-03-2021, 10:22 PM
X66 714's Avatar
We're getting close to having a set
Thanks, Joe
Old 06-05-2021, 10:31 PM
X66 714's Avatar
Thank you for all the reponces. He was able to get everything he needed in one location. Thanks again, Joe
