Old 04-16-2021, 08:39 PM
daleone3 daleone3 is offline
Default 1983 C10 Shortbed 2WD $19k
1983 Chevrolet C-10 Two Wheel Drive Short Bed.
68k original miles with approximately 20k miles on a GM Crate 350 4 barrel
Automatic, PW/PB/PS/Tilt/AC
Red on Red.
Text preferred: Scott 508-328-2349
**Put away for the winter, (Massachusetts) more pics and video available shortly.
I purchased this truck at Carlisle PA Chevy Swap Meet seven years ago. It has NEVER seen a grain of salt and has not been wet as long as I have owned it. The person I bought it from brought this truck to Carlisle to sell from South Carolina where it has been owned by one person and very well cared for. The truck has been garaged as long as I have owned it and not driven as much as I probably should have.
I have no paperwork on the Engine replacement though upon doing the Valve Covers, I found it to be extremely clean. I was told the Engine was swapped at approximately 40k miles which is consistent with the life span of a 305 camshaft.
Exterior:
•Dent free and always rust free. At no time has there been body work with the exception of a very strong paint job at some point, all trim removed, no masking lines or overspray on the door lock gaskets like you see many times. There is one very small door ding on the drivers side courtesy of someone that felt he need to park next to me in a very empty lot one day, small indent, no paint damage.
•Doors, Rockers, Fenders and Cab Corners are complete factory, never worked.
•Has a 2 inch aftermarket hood on it which fits extremely well.
•Bumpers are very good, not perfect but probably an 8/10 in terms of shine.
•Bed is near perfect, not banged up or scratched, does not appear to have never been worked.
•There is not one bubble or indication of rust on the body.
•Brand new Cooper 60’s all around, less than 100 miles on them on factory rally wheels that are in excellent condition with no curb rash.
Interior
•New Headliner. Rest of truck is original including red bench seat, dash, instruments, etc….
•Power windows work but are slow, fairly common for this year truck
•Doors shut as new, and bottoms of doors show no rust or every having any rust.
•Carpet is excellent, appears to be original.
•After market radio, dash is intact and was not cut up to accommodate the fit.
•After market gauges installed under dash tastefully (Oil, Temp, Voltage)
Engine and Suspension
•Very strong running 350/4 tied to an automatic transmission
•Dual stainless-steel exhaust with Headers, runs and sounds very strong. No smoke or hesitation
•Believed to have a shift kit but not 100% sure on that.
•New upper and lower ball joints replaced 100 miles ago. The original riveted ball joints were still in place at time of service.
•New valve covers and gaskets.
•New Battery
•New Sending Unit and Gas Tank. Tank was removed to do the sending unit and in the process developed a small weep on one of the welds so I opted to replace it, was not rust related, likely when it was on driveway and slid out from under the truck.
Undercarriage
•Spotless. No other way to describe it. It has NOT been spray-bombed or undercoated. The factory black paint is still present on most of the frame.
•Frame horns look very close to when this truck left the factory.
•Floors are in the same clean and untouched condition.
•Every nut or bolt on this truck turns freely, not corroded or rusted in any way.
What it needs:
•Cable running from the heater controls to the heater box (included). Never fixed as I do not drive it in the winter so never really needed to.
•There is a minor chip in the windshield, it was there when I bought it and has not changed
•Chrome trim around windshield is original, could stand to be replaced.
•The Gear Indicator (the little orange thing that points to PRND21) broke off.
The Following User Says Thank You to daleone3 For This Useful Post:
downunder1 (04-17-2021)
