Old 04-04-2021, 12:08 PM
R68GTO R68GTO is offline
Default Wire harness clip source
My original harnesses have a couple of broken push clips - the kind that are taped into the wire bundle. Is there a good source for the correct color / size clips? It looks like most new harnesses have white clips which I believe are incorrect.
Old 04-07-2021, 08:57 PM
firstgenaddict's Avatar
yes, white is incorrect - I know of no source currently but was thinking about having 1000 or so made - cost is about $600 so .60 each.
There are 2 which really should be made the a DARK BROWN one with the split retainer pins on a tab and a BLACK or DK BROWN one with the split retainer pins on the back of the part which is woven into the harness
- I thought about painting the repros but then pushing through a hole would scrape off the paint.
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
The Following 3 Users Say Thank You to firstgenaddict For This Useful Post:
R68GTO (04-08-2021), thehornworks (04-07-2021), X66 714 (04-07-2021)
Old 04-08-2021, 12:36 AM
parkbrau's Avatar
parkbrau parkbrau is offline
I pulled a few harnesses from junked cars years ago. Still have them and have used connectors and a few push clips from them.
