Old 02-28-2021, 02:45 AM
69L78's Avatar
69L78 69L78 is offline
Default 69 Camaro 4-speed Back Drive Rod 5773 Versus 5776
Just trying to confirm which lower back drive rod for the 69 Camaro 4-speed is a little longer, the SB 5773 or the BB 5776?
CRG has pics of the BB shift rods versus SB shift rods but no info on lower back drive rods.
Old 02-28-2021, 02:16 PM
William William is offline
BB 5776 is slightly longer.
Old 02-28-2021, 02:57 PM
69L78's Avatar
I agree with you William, and I also had another member tell me the SB is longer. I have had a few numbered 5773 & 5776 rods in the past, but never needed to take a measurement. Now, all you find are rod's with no number's.
Old 02-28-2021, 06:19 PM
The difference isn't much. A bb is offset to the right of course, but is also positioned slightly forward [measured at the rear block surface] compared to a sb.
Old 02-28-2021, 07:10 PM
302moz 302moz is offline
Default Reverse lock out
The BB is shorter.Not by much . I have photos to prove . Had a mint number stamped bb rod and a mint number stamped Sb rod side by side . Always wondered the same question. Can send photos.
Old 02-28-2021, 08:25 PM
Steve Shauger's Avatar
Administrator
Hi John,
Please post the pics. What are the lengths of the BB rod and SB rod. Also exactly what are the points on the rod you're measuring from.
Thanks!
www.vintagecertification.com
Old 02-28-2021, 09:10 PM
WorkinProgress WorkinProgress is offline
Here are some pictures of NOS 3955773 and 3955776 back drive rods with the part numbers stamped into them.
The 3955773 is longer by about 5/16". A tape hooked end to end measures 20 11/16". Center to center on holes is about 20 5/16".
The 3955776 is shorter by about 5/16". A tape hooked end to end measures 20 3/8". Center to center holes is about 20".
- Warren
The Following 3 Users Say Thank You to WorkinProgress For This Useful Post:
RobR (03-01-2021), Steve Shauger (03-01-2021), William (02-28-2021)
Old 02-28-2021, 11:00 PM
69L78's Avatar
- Warren
Thanks Warren for the pics, when John adds his pics to also verify, I am glad we can end this discussion with everyone on the same page. These rods over the years also get altered or bent and add to the mix.
Old 02-28-2021, 11:05 PM
Default Rods
Great photos Warren ! We are on the same page . Will post photos.
