Old 02-19-2021, 03:25 AM
Motorhead848 Motorhead848 is offline
Default 69 and 70 z28 parts
cleaning the parts inventory out and here is a list of 69 and 70 z28 parts i have that i do not currently have a need for:
1. 668CG crank pulley. this is a gm pulley. its been powder coated and was used. but i replaced it done the road with an NOS one. has some damage on the inside but still spins pretty straight. $150 now 125
2. AAC booster hose bracket. real gm piece no pitting. $450 SOLD
3. 1969 rear bumper guard cores. decent shape. good cores for a chrome shop. $40 now $20
4. aluminum valve covers. i believe these to be the later NOS versions as they are polished and have part numbers in them. were on the car when purchased but found correct non drippers for it. $200 now $150
5. YH rally wheel dated k19-5-stem hole. this wheel was on the car when i had found it with a flat tire in the dirt so there is a section about 6" on the outer lip that has some rust damage. probably good for a spare since that face is down. $250 now $175. SOLD
6. 1970 fan shroud. this shroud has some damage to the lower section but the top section is still good. perfect for someone with the opposite condition. $75 now $40
7. 1970 5618 back drive rod. this is the elusive lower back drive rod for a 70 z28. this is a GM piece with the stamp in it. recently acquired a complete set up from a fellow member so letting this one go. looks like someone might have taken the bend out but could easily be put back in. $400 SOLD
8. reproduction gold cad delco booster. this came with a project but i like to restore the original stuff. this has not been installed and is still in the original box. cost $189 new. $125 now $100
9. reproduction 1970 dual snorkle air cleaner base. good shape. $200 now $100
i just used a general picture of the parts. if you would like more detailed pictures of a specific part please text me and i will be more then happy to do so. PPFF is preferred. all prices are plus shipping.
(408)821-2927
-Mark
Last edited by Motorhead848; 03-18-2021 at 11:44 PM. Reason: forgot to list an item
Old 02-19-2021, 03:04 PM
Pacecar1969 Pacecar1969 is offline
Do you have a full date code for the wheel? thanks
Old 02-19-2021, 04:01 PM
K19-5-stem hole. Valve stem punched the day out.
Old 03-11-2021, 02:45 AM
price drop. see original post
thanks
