Old 12-29-2020, 06:33 AM
Damien Damien is offline
Default Attention Ignition Guru's
Hi all.
Hope everyone had a great Xmas.
Looking for some ignition advice for my Chevelle ('69 396/350 4 speed) as the MSD RTR 8360 has killed the coil and the module. As all of this gear has been made in China, like most, for years and I don't want to throw good money after bad, I'm looking at changing it out to something more worthy and would like some recommendations if I can?
I was thinking either a 1111498 with a Pertronix set up, a Pertronix Stock Look distributor or, given my Chevelle is a driver, a 1111498 with a points set up.
TIA.
1969 SS 396/350 Chevelle
Old 12-29-2020, 10:45 AM
JRSully JRSully is offline
I have a Crane pointless system in the orig distributor for my L78. It has worked flawlessly for 10 yrs or so, I've never had to touch it (knock on something)
71 Porsche 911 Targa
The Following User Says Thank You to JRSully For This Useful Post:
Damien (12-29-2020)
Old 12-29-2020, 11:49 AM
jl8z28 jl8z28 is offline
I have the 498 with points mine runs fine
The Following User Says Thank You to jl8z28 For This Useful Post:
Damien (12-29-2020)
Old 12-29-2020, 12:26 PM
I run factory points in the concourse restored cars.....for daily drivers or local car cruise cars....(for well over a decade) I have used a Pointless One Wire System. I have tried and used various systems they are all very similar and work great!
Damien for your Chevelle....I would definitely go with a pointless system. Very easy install.
The Following User Says Thank You to Postsedan For This Useful Post:
Damien (12-29-2020)
Old 12-29-2020, 01:32 PM
Too Many Projects's Avatar
I have a friend who uses the Crane conversion, exclusively, and swears by them. I have Pertronix internal conversion in 2 original distributors and the original appearance replacement in 2, WITH the correct, matching ohm coils. Why Pertronix continues with the different ohm coils is beyond me. With the correct coils, I have had no problems in 10 years. The higher voltage will produce faster starts and better throttle response.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Damien (12-29-2020)
Old 12-29-2020, 04:34 PM
1967 4K's Avatar
1967 4K 1967 4K is offline
I’ve had a Pertronix system in my car for 15+ years with no issues. Easy to install also.
1967 4K
Richard
1967 Camaro SS 396/375 4K
The Following 2 Users Say Thank You to 1967 4K For This Useful Post:
Damien (12-29-2020), earntaz (12-29-2020)
Old 12-30-2020, 05:14 AM
Quality coils seem to be on the endangered species list.
Is there anyone in the US still making oil filled coils? I like to buy a couple of quality coils and bypass the Chinese junk if I can.
Thinking I may go with a Pertronix Ignitor 11 D104600 at this stage.
Old 12-30-2020, 01:08 PM
Summit lists your number as an Igniter I. This is the unit I buy...Igniter III D7104600
Summit's description lists this as magnetic, but Pertronix lists it as a multi spark, which seems to be a hall effect...
They don't seem to list as much info about the products anymore, such as the ohms of the distributor for the correct coil. Looking at "suggested parts" shows both ohms for this distributor ??????? Might want to call Pertronix direct and get the info.
Mitch
1970 Chevelle SS
1966 Chevelle SS
1967 Camaro ss/rs
Damien (12-30-2020)
