Old 12-15-2020, 09:13 PM
SeattleCarGuy SeattleCarGuy is offline
Default Engine date vs Build date
Friend is looking at a '69 Camaro. Its an 11D build date and the engine pad stamp (L35 396) shows a November 19th engine build date.
This seems way too close??? Shouldn't the engine have a build date at least a month or so prior to the car?
Thanks in advance
Paul
'62 Bel Air 409/409
'63 Impala SS 409/340 convertible
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 12-15-2020, 09:24 PM
jdv69z's Avatar
jdv69z jdv69z is offline
No, that's probably about right. Norwood Car? Only about 5 hours from Flint to Norwood.
Jimmy V.
Old 12-15-2020, 09:27 PM
But this a big block so its a Tonawanda engine. You still think its ok?
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Old 12-15-2020, 09:30 PM
Copo_Cartel's Avatar
Copo_Cartel Copo_Cartel is offline
Yenko Premier Member
It is fine. No issues with date at all
The Following User Says Thank You to Copo_Cartel For This Useful Post:
SeattleCarGuy (12-15-2020)
Old 12-15-2020, 10:42 PM
X66 714's Avatar
X66 714 X66 714 is offline
11D was a projected date. Do you know the date of the completion of the car? Do you have the NCRS report?...Joe
Old 12-15-2020, 11:12 PM
William William is offline
Final-assembly for 11D bodies spans November 20-December 4. I suspect the car in question is one of the last 11Ds, VIN N5536xx. 8 VINs later, a 12A body was built with a November 30 L35 engine.
Less than 8 hours drive from Tonawanda to Norwood.
The Following 3 Users Say Thank You to William For This Useful Post:
SeattleCarGuy (12-15-2020), X66 714 (12-16-2020), Xplantdad (12-15-2020)
Old 12-16-2020, 01:39 AM
X66 714's Avatar
My 325hp has a cast date of H129, engine build date of 8/21 & an assm date of the car 8/28/1969. This one is actually a factory 402....Joe
Old 12-16-2020, 12:33 PM
x33rs x33rs is offline
I think my 69 Z is very similar. It's a Norwood 12D build and I think the assembly stamp on the engine is near the very end of the month of December. According to the serial number I think William told me my Z was actually final assembled 1st week of January.
Kind of interesting my serial number is about 500 numbers beyond some 12E builds from Norwood, which the first ZL1's were I believe. So my Z was scheduled a week before but came out about a week after the 12E cars. There was a hang up somewhere. Interesting stuff.
Old 12-16-2020, 01:50 PM
In many decades of '69 Camaro data-mining, only two 12E cars are known: ZL1s #1 & #2.
If you want your cars moved up the schedule, ask the General Manager to make the request. This is at the bottom of the Broadcast Copies for #1 & #2. These ZL1s had body numbers #222002 & #222003. #222001 was ZL1 #14, built March 5th.
However, none of Gibbs' cars was the first ZL1 ordered. That was Berger Chev ZL1 #3, body #211785, built March 4th.
The Following 4 Users Say Thank You to William For This Useful Post:
Copo_Cartel (12-18-2020), m22mike (12-16-2020), Steve Shauger (12-16-2020), X66 714 (12-16-2020)
Old 12-16-2020, 02:33 PM
ALLZS ALLZS is offline
my 09D OF 1968 IS CAST I-11-8 BUILD VO912DZ
