Does anyone know what this intake is off of? Looks like a 472 intake but there is no casting number. The rest of it looks good to me but thinking it had to have been a LT-1 intake to have the snowflake but no part number or perhaps a GM parts intake sold over the counter?
Thinking of tumbling it and using it but would like to know what it is? ![]() ![]() ![]() ![]() ?
----Was I wrong.
Last edited by olredalert; 11-01-2020 at 02:31 PM. Reason: You would think I could spot a small block intake. DUH! |
It’s a early issue 1971 Z28, with the cast over oil fill tube hole, late 71 and 72 up had the cylinder numbers on runners. Take bottom shield off to check date, that will tell you.
| The Following User Says Thank You to rszmjt For This Useful Post: | ||
NorCam (11-02-2020) | ||
Thanks Mike. I'll take the splash shield off when I have it tumbled next week. Much appreciated.
Norcam did you make your own tumbler?
No way i would of tumbled that intake. I use Navel Aluminum Jelly from Loctite. Great cleaner. Soak intake in real hot boiling water, remove and brush on this Aluminum Jelly let it set for a good 10 minutes, put intake back in boiling hot water and brush off with a good paint brush. This will leave a natural casting finish just like the intake came out of the foundry. Just my two cents.
Should have it Vapour Blasted. Don Fergin @ Universal Cycle in Calgary, tumbling kinda doesn’t look natural, makes them to dark. JMO.
I may have found another 472 so perhaps I'll clean this one and offer it up to someone with a 71 Z.
Thanks again for the info.
Probably a replacement 116 intake, 1970 LT-1 usage.
70 Camaro LA Z-28 03B Citrus Green LT-1 M-40 3.73's 69 Camaro X-77 Z-28 10C Cortez Silver M-21 3.73's Deluxe Project X - SOLD 69 Camaro X-77 Z-28 01B Garnet Red w/Black top, M-20 3.73 Deluxe Houndstooth |
