Old 10-15-2020, 06:37 PM
RALLY RALLY is offline
Default Used 1969 327 Bare Block-Std Bore
Used 1969 327 Block. This is not a complete engine, block only. Block cast number 3959512. Cast Date B-27-9. Pad Stamped 0411FC. According to a very well known retired GM engineer i contacted the 9512 block only had one production application 69 passenger 327 2-barrel automatic but it was used for many years as a primary Service replacement and CE 5/50 warranty block for 4 inch bore applications. 2 bolt Block. It was the last block that was cast with the crankcase vent tube hole at the back and was machined in both small journal and large journal configurations. Restorers like the 512 block as they can have a proper functional and correct PCV system and still use the early factory finned aluminum valve covers without holes. Block is Std- Bore Large Journal. Good block for a nice street car or racing application. Good 327 blocks are getting hard to find. Block needs a good cleaning and is greased for rust protection. Local pick up only, you have to come and pick up the block. Block is located in Mich. Will not ship or deliver. If interested, send me a message for pictures. 200.00 dollars FIRM.
