Old 10-11-2020, 07:47 PM
Motorcity23 Motorcity23 is offline
Default 3955272 Block dated H-7-8
60 over
I took this running engine out of my Chevelle about 15 years ago. Has been stored in heated garage and fogged occasionally ever since. The motor had fairly recently pretty mild rebuild.
When I pulled the engine I noticed a repair of a small (I assume) crack. It seems there was coolant seeping from the weld as there is some discoloring around the area (see pics). Very clean on the inside when I took it apart.
Selling bare block with mains, although I have the 6223 crank (10-10), 60 over pistons w/rods, oil pump, oil pan, cam, lifters, and push rods if you are interested.
It's oily and the gaskets are not scrapped off. If I don't sell it i"ll have it welded up and rebuilt.
Tom $275, In the metro Detroit area
Attachments - The Supercar Registry weld2.jpg weld1.jpg IMG_3368.jpg IMG_3363.jpg
