I have never seen an NOS RS inner fender for a '69 Camaro and I have actively been searching out parts for over forty years. So based on that, I would say they are rare.
I believe you can take standard inner fenders and punch out the hole size you need on the dimple marks to convert to RS. Greenlee sells all the punch sizes so you can make it look factory. The RS inner fender part numbers are 3945791 LH, 3945792 RH. Standard inner fenders are numbers 3935917 LH, and 3935918 RH The 3945792 RS RH inner went discontinued on 7/80 and superseded to the standard inner fender. The LH RS went discontinued just prior to the RH side. - Warren |
| The Following User Says Thank You to WorkinProgress For This Useful Post: | ||
NorCam (09-18-2020) | ||
There's still some good used one out there. I sold some a couple of years out....Joe
1968 Z/28 Corvette Bronze. Black Hounds Tooth. 02E Los Angeles born 3/13/1968 pnt OO 1969 SS396 Yellow/Yellow 08E Norwood born 8/28/1969 pnt 76E 1970 'cuda Moulin Rouge, 440-6, 4 speed |
Thanks. I have to check the part numbers to see if someone put the holes in mine or if they are actually NOS RS ones.
Even good used are hard to find. I have never seen an NOS pair either.I think Warren is right, you could only buy the NON RS ones and had to cut the holes.
1969 Camaro RS/SS Azure Turquoise 1969 Camaro Z/28 Azure Turquoise 1984 Camaro z/28 L69 HO 5 speed 1984 Camaro z/28 zz4 conversion 1987 Monte Carlo SS original owner |
I have NOS GM white tag RS Inners if anyone needs picts or reference info
Also have good used RS ones for same info Not looking to sell as they are set aside for projects I'll loan anyone a Greenlee punch stud and I'll check my Knock outs and hole saws for sizing to see if I have any that match up.
Fred [email protected] 610-585-4155 WANTED: 1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting Always looking for dated L78 parts from Jan-Apr 69 Last edited by L78 Fred; 09-18-2020 at 11:05 PM. |
| The Following User Says Thank You to L78 Fred For This Useful Post: | ||
enio45 (09-19-2020) | ||
