Old 08-25-2020, 01:28 AM
frankk frankk is offline
Default 69 Camaro Fan Shroud And Fan Clutch
Do I have to drill out the three rivets at the bottom of the rad in order to remove the shroud. Its a small block car and I believe its an original rad and shroud setup. Also how do you remove the fan clutch. Do I need a puller to pull it off the shaft? Thanks in advance Frank
