Old 07-21-2020, 05:32 AM
Default 69 Malibu Rear Panel Moldings & Clips
Looking for OEM (not reproduction) upper and lower moldings for a 69 Malibu, that go on the panel between the tail lights. Also want the 16 original mounting clips that hold them in place: 6 upper and 6 lower plastic clips that fit into the elongated mounting holes on the rear panel; 2 upper and 2 lower metal clips with threaded stud that go thru the round holes at either end of the panel. PM or email, and thanks in advance!
Bill Pritchard
Old 07-21-2020, 01:32 PM
L72Biscayne L72Biscayne is offline
Do you have a picture of them. I have a lot of old Dorman and Aveco hardware from the 70’s.
1970 Z28 Citrus green CW 3:73 1970 Ls6 Cy 3:31 14K miles 1968 Biscayne L72 M22 952 actual miles. 1966 Biscayne L72 3:73 1966 Chevelle L78 M22 4:56
Old 07-21-2020, 01:44 PM
As far as the unique plastic oval hole clips....GM made several different sizes for various cars.
You must make sure you have the correct sizes.
Old 07-21-2020, 03:20 PM
I actually do have pictures, provided by a very helpful member on this site. But as Dan says, GM made different sizes for different applications, so I think I would need to have actual measurements (which I don't have) in order to pinpoint which ones I need. Thanks for your inquiry though!
Bill Pritchard
Old 07-21-2020, 06:28 PM
Here's a picture of what all four types of the necessary clips look like. Picture courtesy of Phil Woj
Bill Pritchard
