Old 07-09-2020, 09:45 PM
bbbentley's Avatar
Default ZL1 Cam Cold Lash
From what I could find, the 9181 ZL1 has a hot lash of I=.024, E=.026 ? Anyone care to give a cold lash setting? I’m guessing subtract .002 off the above specs? Any help appreciated. Thanks sYc.
FULL OWNER HISTORY
Old 07-09-2020, 10:43 PM
L_e_e's Avatar
L_e_e L_e_e is offline
With iron heads you want to ADD 0.002"
The Following User Says Thank You to L_e_e For This Useful Post:
bbbentley (07-10-2020)
Old 07-09-2020, 11:34 PM
jerry455 jerry455 is offline
What if engine has factory aluminum heads? Still add .002?
Old 07-10-2020, 12:06 AM
lbnaz lbnaz is offline
I set mine as per specs w/alum heads and had no issue. Larry
Old 07-10-2020, 12:22 AM
RobR RobR is offline
Head material?
Block material?
Old 07-10-2020, 12:24 AM
bbbentley's Avatar
Originally Posted by RobR View Post
Head material?
Block material?
Iron&iron. Basic L72 w zl1cam
FULL OWNER HISTORY
Old 07-10-2020, 12:31 AM
rszmjt rszmjt is offline
Iron heads & block add .002. With aluminum heads set cold lash tighter about .005-.006 on a rat motor. If it’s aluminum block & heads about .010 tighter cold. The thermal expansion of aluminum causes the lash to increase hot.
The Following 3 Users Say Thank You to rszmjt For This Useful Post:
bbbentley (07-10-2020), jerry455 (07-10-2020), L_e_e (07-10-2020)
Old 07-10-2020, 12:46 AM
Like you said, I would go .002” LESS than the hot lash spec. ‪for break-in.‬ Then
‪with the engine at running temp, shut it off, and set the valves on one cylinder to the Hot lash on the cam card.‬
‪Let the engine fully cool down. ‬
‪Measure the lash on that cylinder that you set hot.‬
‪That will be the cold lash setting to use on all the cylinders.‬
The Following 2 Users Say Thank You to RobR For This Useful Post:
Old 07-10-2020, 03:03 AM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
If it is a aluminum block and heads set .012 tighter when cold. .012 .014 You will be very close to your .024 .026 when hot.
The Following User Says Thank You to KenMaisano For This Useful Post:
Old 07-10-2020, 08:56 AM
bbbentley's Avatar
Trusting my own experience, and your reassurance, I set them .002 tighter or I.022-E.024. Great idea on the reverse calculating lash method.
FULL OWNER HISTORY
The Following 2 Users Say Thank You to bbbentley For This Useful Post:
jerry455 (07-10-2020), RobR (07-10-2020)
