Old 07-01-2020, 06:38 PM
ALLZS ALLZS is offline
Default Correct motor mount
what would the assembly line correct motor mount be for a sept of 68 built Z/28 are the small block & big block mount the same ?
Old 07-01-2020, 08:44 PM
William William is offline
An initial '69 P & A lists 3939728 for 302 & 350; 3937930 for the BB. By 1971 3990918 was used for both. There were several changes & suppliers over the years.
Production parts may be unique, based on guys I know hoarding them.
Old 07-01-2020, 09:37 PM
NON locking correct?
Old 07-01-2020, 11:13 PM
firstgenaddict's Avatar
They are not reproduced and no the big block and small block ones are not the same, they are similar however not the same.
The mount could be reproduced which would not separate by using two interlocking stamped steel plates with the rubber injected into the void.
What is the market for correct 1969 Small block HP motor mounts?
~JAG~
NCRS#65120
NUMEROUS Lemans blue Camaros,
& a Chevelle or two...
