Old 05-09-2020, 05:34 PM
ssl78 ssl78 is offline
Default 1969 L88 engine
This is a complete running 1969 427 L88 engine minus brackets and pulleys. There is a new timing chain, the heads have been redone, new rear main seal and all gaskets are new. I believe it could be a original L88 but the block has been decked it looks like the motor was blueprinted and balanced. The engine has original L rockers that came with assy line engines.The engine is on a run stand so you can hear it run. 7800.00
69 dated 074 heads with xxx by casting number
Block 3963512 4 bolt main F149
Crank 7115 with GMM420 bearings standard standard
7/16 dimpled rods full floating
Heads 3946074XXX 9-30-9 10-17-9
8 in AOR timing cover
L rockers with GM push rods
GM pistons standard bore
intake 3985069carb
3886091-an
69 RS SS L78 conv
69 RS SS ZL1
69 L78 Chevelle conv
69 L78 Nova
69 L34 Nova
67 SS Chevelle
73 Trans Am
The Following User Says Thank You to ssl78 For This Useful Post:
L78M22Rag (05-10-2020)
Attachments - The Supercar Registry DSC04351.JPG DSC04350.JPG DSC04349.JPG DSC04313.JPG
