Old 04-21-2020, 01:54 AM
1crossram 1crossram is offline
Default 67 Camaro parts wanted 350 with AC and smog
looking for the following items for a 67 Camaro 350 with AC and smog
Smog tube for passenger side exhaust manifold
starter motor front support brace
front licence plate bracket Found thanks
oil dipstick
seat belts deluxe in black prefer dated October 1966 without retractors
power brake pipe and support for intake manifold with power brakes
AIR pulley #3887101 Found thanks guys
alternator Pulley #3909817
bracket for adjusting smog pump that bolts to top water pump bolt (where alternator bracket attaches) Found thanks guys
Thanks
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Attachments - The Supercar Registry SAM_6021.JPG SAM_6020.JPG IMG_4733.JPG IMG_4732.JPG
Old 04-21-2020, 11:50 PM
BARRY BARRY is offline
Default pipe
is this the pipe
Barry Allan
The Following User Says Thank You to BARRY For This Useful Post:
1crossram (04-22-2020)
Old 04-22-2020, 12:37 AM
AMANOCC AMANOCC is offline
Default 67 passenger side smog tube
Here are some pics of a 67 passenger side exhaust, not sure if A/C cars are any different, I didn't remove this from a car, so not sure if its application is A/C or non-A/C.
Old 04-22-2020, 12:39 AM
Manifold is dated K-7-6, hope this helps you find what your looking for...
The Following User Says Thank You to AMANOCC For This Useful Post:
Old 04-22-2020, 02:38 AM
Barry those tubes are not what I need.
Amanocc, yes that is what I need. I only need the smog tube as I already have the manifold. Let me know if you are wishing to sell the tube section only.
Thank you both.
Old 05-08-2020, 07:49 PM
Default parts needed
Bump
