Old 04-16-2020, 06:42 PM
southernfriedcj's Avatar
Default Time waster/stupid question.
Let's say all 3 cars were very well restored to an identical standard and they were all optioned the same and in the same condition.
Which would you rather have?
1970 Chevelle SS LS6/4spd with a non matching numbers engine block
1970 Chevelle SS LS5/4spd with a matching numbers engine block
1970 Chevelle SS LS5/4spd with a 1970 LS6 engine
I would rather have the matching #'s LS5 car although I believe the non matching #'s LS6 car would be more valuable(correct me if I'm wrong on the value).
The Following User Says Thank You to southernfriedcj For This Useful Post:
PeteLeathersac (04-17-2020)
Old 04-16-2020, 06:55 PM
Lee Stewart's Avatar
Old 04-16-2020, 07:34 PM
muscle_collector muscle_collector is offline
is the LS6 documented? are any or all of them documented?
Old 04-16-2020, 07:49 PM
PeteLeathersac's Avatar
Does 'Matching #'s' mean restamp or original engine?
Is the engine w/ #3 an original engine from another LS6 car or just built to LS6 specs
Either way, I'd choose #1 if an original LS6/4-Spd. car w/ engine MIA.
~ Pete
Old 04-16-2020, 08:06 PM
carnut4life carnut4life is offline
I'd take the LS5/M22 car with the original engine and agree the LS6 would be the most valuable if documented.
Old 04-16-2020, 08:54 PM
GrumpyJeff's Avatar
The NOM LS6 would be my obvious Choice ,For pure King of the Hill, Beat on it pleasure without worry of hurting the #'s matching/Born with motor. And that's not even taking the desirability/value of it into consideration !
Old 04-17-2020, 01:00 AM
Each car has all docs.
#3 has the engine from #1.
You can't buy #3 and then go after #1 because when you get one the other two don't exist.
Old 04-17-2020, 01:29 AM
So like real life, car #2 w/ Matching #'s needs scrutiny to determine if original engine or restamp?
~ Pete
Old 04-17-2020, 03:21 AM
Has it really come to this?
The OP sets up a simple question and members are focusing on docs or re-stamps, etc.
ORIGLS6 (04-17-2020)
Old 04-17-2020, 04:23 AM
I was only pushing the matching #'s point as many still feel this indicates THE original engine when it absolutely does not unless proven otherwise...sorry but carnut4life's post above is a good example w/ LS5 now sporting the original engine yet was only matching #'s in description above.
~ Pete
