Old 03-14-2020, 04:39 PM
dlv4540 dlv4540 is offline
Default 1969 ZL1 NOS Enigne #3946052
1969 NOS ZL1 block casting 3946052 dated 3-1-69 with no stamping on front pad and stamped on underside T 08 0 by flat spot where oil filter spins on. I had new speciality ordered sleeves made for the block and installed.
4296 holley carb dated 893 needs restored.
3946074 aluminum heads dated 8-22-70 & 10-1-70
3933198 intake dated 8-10-70
3975928 aluminum water pump
7115 steel crank standard
TRW factory size replacement pistons
7/16 dimple rods
Internals balanced and engine is ready to be built. $35,000
I also have a 1968-69 tall deck 4.40 standard bore version of this block as well #3946052 and has a date code of 06017 on backside. Block was pressure tested and ready to build $8,000.
Can ship if you cannot pick up. I can be reached at 330-770-2517 for any questions.
Dennis Vugrinovich
Attachments - The Supercar Registry 427 1969 8.jpg 427 1969 39.jpg 427 1969 36.jpg 427 1969 30.jpg
Old 05-11-2020, 03:44 PM
bump
Dennis Vugrinovich
Old 06-21-2020, 03:57 PM
bump
Dennis Vugrinovich
Old 08-03-2020, 12:42 PM
bump
Dennis Vugrinovich
