Old 02-24-2020, 03:03 PM
dlv4540 dlv4540 is offline
Default 1965-69 BBC Hi Performance Parts
1965 396 4 bolt standard bore block casting 3855962 dated E-27-5 with IE code 425HP.
Block was cleaned and magged $3000.
1968-69 ZL1 tall deck 4.40 standard bore block casting 3946052 with a date code on the backside of 06017. Block was pressure tested and is a good rebuildable core $8,000.
1969 ZL1 427 NOS block 4,25 standard bore car deck with a casting 3946052 dated 3-1-69.Block has a T 08 0 stamped on the underside by the oil filter and nothing stamped on the front pad. Block has all new sleeves installed and is ready to build.
4296 holley carb dated 983 needs rebuilt
3946074 aluminum heads dated 8-22-70 & 10-1-70
3933198 aluminum intake dated 8-10-70
7115 steel crank standard
7/16 dimple rods
TRW replacement factory size pistons
Rotating assembly has been balanced
3975928 aluminum water pump
$35,000 for the complete set up
1969 3919840 square port heads dated J-30-8 & J-31-8 cleaned, magged and sprayed down in primer. Heads have some porting on the exhaust size and oversized valves. I have all new hardware to go with the set to build them. $1250
1969-70 Water pump pulley #3932430 $35.
PF25 ac delco oil filter with box blue $25
AC delco new spark plugs R43 & R44 sets $20
AC delco 195 degree thermostat in the box $5
Manley double roller timing chain used for break in only $25
New high volume oil pump $50
New blue streak cap and rotor $20
I can be reached at 330-770-2517 for any questions and can provide pictures with a email address. I can ship if you cannot pick up as well.
Dennis Vugrinovich
