Old 02-17-2020, 02:27 AM
R68GTO R68GTO is offline
Default Big Block Alum intake bolts
Did a search to no avail.... Trying to get the right fasteners in the right place to bolt up my alum. intake. I'm confused as to where the stud bolts go vs the regular bolts. One for the alternator bracket and one for the fuel Y block. Stud bolt anywhere else?
The Following User Says Thank You to R68GTO For This Useful Post:
bbjohnny (02-19-2020)
Old 02-17-2020, 02:54 AM
William William is offline
Yup; 3 on the LH side near the carb. This is from the ZL1 engine manual but same as L72.
Two of them were used for the idle solenoid bracket some auto cars received. It's in the M40 section of the AIM, page A10. No idea what the third stud was intended for.
Fuel line bracket was a late production [June?] addition.
Old 02-17-2020, 11:13 PM
Flying Undertaker Flying Undertaker is offline
The three studs on the driver's side of the intake are for automatic equipped cars, i.e., the idle solenoid bracket and the TH 400 Kickdown bracket. Don.
Old 02-17-2020, 11:26 PM
The kick down bracket mounts on a carb stud, not the intake.
Old 02-17-2020, 11:42 PM
Thanks for the feedback guys. So would a manual equipped car just get the two studs on the passenger side or did all get the same regardless of trans selection?
Old 02-18-2020, 12:04 AM
All three, as shown in original pics of ZL1 #3. Nothing mounted on them.
The Following User Says Thank You to William For This Useful Post:
R68GTO (02-18-2020)
Old 02-18-2020, 04:00 PM
Thanks, William, concerning the kickdown bracket mounting. Had a brain fart, should have known better. It's hell to get OLD! Don.
Old 02-18-2020, 04:08 PM
z28s4mjg z28s4mjg is offline
Default intake bolts
Hi Don,
I have a picture of them on Eddie M's. ZL1 #12. I can send it to you if you give me a phone number or email address. Don't know how to post pictures here.
Mike
Old 02-18-2020, 04:22 PM
Mike: Thanks for the offer but I took pics of Eddie's #12 car at MCACN. Don.
Old 02-18-2020, 08:02 PM
m22mike's Avatar
m22mike m22mike is offline
Originally Posted by z28s4mjg View Post
Hi Don,
Mike
Mike
I would like to see it and will post it up for re; email it to
x66@( remove this) neo.rr.com
Thanks Mike
