Old 02-17-2020, 12:05 AM
302moz 302moz is offline
Default 69 z28 front coil springs
Looking to purchase a pair of front coil springs for my 69z.Who sells the correct ride height springs? or a Moog part number? anyone? Thanks
Old 02-17-2020, 02:43 PM
jdv69z's Avatar
jdv69z jdv69z is offline
You need to know which springs your car came with. Springs vary depending on options which affect the weight of the car.
Jimmy V.
Old 02-17-2020, 02:55 PM
Billohio Billohio is offline
Pozzi racing has some good info on 1st gens with Moog part numbers. Thats what I used.
http://www.pozziracing.com/camaro_sp...fo.htm#SPRINGS
Bill
Old 02-17-2020, 03:48 PM
Steve Shauger's Avatar
Administrator
I purchase Moog 6308 because from my understanding the car will sit a tad 1" lower than stock. I plan to install in the spring. I have a set of used originals but rather install new springs.
www.vintagecertification.com
NorCam (02-17-2020)
Old 02-17-2020, 04:31 PM
x77-69z28's Avatar
Steve, I have the best coil spring compressor. Let me know when you plan to do it!
Buddy
Old 02-17-2020, 06:59 PM
NorCam's Avatar
NorCam NorCam is offline
What spring compressor are you using Buddy?
I have new springs in my blue Z, and although it sits right, I'm not sure what springs the PO used. Also, have the originals which I am thinking of putting back in now that they have been cleaned up. Always looking for good tools that make life a little easier and or safer when changing springs.
Old 02-17-2020, 11:01 PM
Default springs
Mechanics wire is the best tool to use. First you compress them in a strut compressor and then wire them. Works great. Still have all my fingers.
Old 02-18-2020, 01:00 AM
I am pretty sure I used 6308 on a non RS car
Bill
