Old 02-13-2020, 05:34 PM
chris slawski chris slawski is offline
Talking 396 L78 block
Hey folks-
Can a L78 4 bolt block 69 vintage accept an over bore to 4.250 for 427 displacement or will it become unstable?
asking for a friend
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
Old 02-13-2020, 07:05 PM
dustinm dustinm is offline
Pull a soft plug and see if you can stick a pencil between the cylinders. I believe this block will be too new and it will fit, but that is the easiest way to see if it is even a candidate.
The Following User Says Thank You to dustinm For This Useful Post:
chris slawski (02-13-2020)
Old 02-13-2020, 10:40 PM
JRSully JRSully is offline
I know the 854 70 L78 blocks can take a big bore job, they are actually 30 over 396's (402) from the factory
71 Porsche 911 Targa
The Following User Says Thank You to JRSully For This Useful Post:
chris slawski (02-14-2020)
Old 02-13-2020, 11:20 PM
big gear head's Avatar
The cylinders are going to be awful thin if you do.
Freddie
Old 02-13-2020, 11:31 PM
If you are looking for performance not sure the 427 has much over the L78 configuration to risk that bore.
The Following User Says Thank You to Salvatore For This Useful Post:
Old 02-14-2020, 12:52 AM
bbbentley's Avatar
A 69 big block of any C.U. Or horse is worth more with as little overbore as can be done to clean up the block, imo. A heavy overbore diminishes any 396 or 427. With so many gen.4 454 blocks available, there is no need or reason to bore a 396 out that much, if it can even safely be done.
FULL OWNER HISTORY
The Following User Says Thank You to bbbentley For This Useful Post:
Old 02-14-2020, 02:05 AM
wvhylander wvhylander is offline
Bore it .060 buy a set of UEM Pistons($650) and a Scat 4" stroker crank and you have a 434ci. motor. Step up to Ross pistons ($1100) and a 4.25 stroke crank you have a 461ci. from a 396 block.
The Following User Says Thank You to wvhylander For This Useful Post:
Old 02-14-2020, 06:43 PM
As JRSully said,if the block is one of the late 1969 production & really a 402cid,you should be fine.
Easiest way to identify one is if it has a 3 letter Suffix code on the machined pad beginning with the letter "C"...example CJD or CKF,as opposed to just JD or KF.
Old 02-15-2020, 04:45 PM
L78steve L78steve is offline
The early 65 Fang 396 block has lots of meat also.
Old 02-15-2020, 06:13 PM
plumL78 plumL78 is offline
I have a 65 396 punched to a 427 bore. we used hard block to stabilize the cyls. been in my car for many years but its an early block
