Old 02-02-2020, 06:08 PM
lbnaz lbnaz is offline
Default Muncie Shifter ID
Looking for the identification and application of this Muncie 4 speed shifter. One rod has 1437, one 1438, and other one 2535 on it. They all appear to be original to the shifter. It has a black and chrome knob. It came on a 4 speed I bought awhile back. Thanks, Larry 520-349-2337
Attachments - The Supercar Registry IMG_5746.JPG IMG_5745.JPG IMG_5744.JPG IMG_5743.JPG
Old 02-02-2020, 07:32 PM
XXXGoldL34M20's Avatar
My guess is 1968 to 1972 Chevelle
Handle is console but top ball is Non Console or Bench seat IMO
My 1970 Assembly hear at home has the same part numbered rods.
The Following User Says Thank You to XXXGoldL34M20 For This Useful Post:
lbnaz (02-02-2020)
Old 02-03-2020, 10:52 AM
JoeC JoeC is offline
shifter looks like Nova with console also fits 67-68 Camaro
it has the second design Reverse detent
It has large slot trans levers for 69-72
68 used small slot trans levers
no Munice trans in 72 Nova
so shifter looks like Nova 69-71 with console
rods and levers may be Chevelle 69-72
The Following User Says Thank You to JoeC For This Useful Post:
lbnaz (02-03-2020)
Old 02-03-2020, 04:33 PM
dboles dboles is offline
I thru one of those away back in '71. Replaced it with a Hurst C/P.
Old 02-04-2020, 06:05 PM
WorkinProgress WorkinProgress is offline
Larry,
Shifter rods in my Oct '69 parts book show 3931437 1st & 2nd, 3931438 reverse, 3922535 3rd & 4th. Parts book says 68-69 Chevelle w/4spd (327 Sp. H.Per., 350, 396) (exc 2BC).
Might also fit '70 up Chevelles but this is a '69 parts book.
If you can get a partial part number off of the shifter handle, I will look that up for you.
- Warren
The Following User Says Thank You to WorkinProgress For This Useful Post:
lbnaz (02-04-2020)
Old 02-04-2020, 06:58 PM
I'm not seeing any numbers on the handle or the body of the shifter. The ears have 1-2, 3-4, and on reveres 289 maybe 2891 on them. Thanks for your input. Larry
Old 02-06-2020, 12:17 PM
Its not a Chevelle or Impala shifter , they had bolt on chrome sticks
Camaro Nova had welded on chrome sticks
the rods and levers are not correct for that shifter
lbnaz (02-06-2020)
Old 02-07-2020, 12:33 AM
That shifter is a mixture of Chevelle rods and levers and a Camaro - Nova Shift body.
The rods are 68-72 Chevelle and the levers are 69-72 because of the bolt on design of the levers for 69-up Muncies.
The shifter Body looks like Early Camaro or Nova due to the 1 piece handle but I'm sure there are guys here that can tell you exactly what it fits.
Chris
The Following User Says Thank You to Ls6 Ragtop For This Useful Post:
lbnaz (02-07-2020)
