Old 01-20-2020, 04:04 PM
dlv4540 dlv4540 is offline
Default ZL1 Aluminum Blocks & Parts
1969 39460562 aluminum NOS block never run dated 3-1-69 with all new sleeves installed ready to build. 3946074 aluminum heads dated 8-22-70 & 10-1-70 along with the 3933198 aluminum intake dated 8-10-70. 4296 Holley carb dated 893 will need rebuilt and recolored along with factory aluminum water pump 3975928.
7115 steel crankshaft standard along with 7/16 dimple rods and factory replacement TRW pistons all balanced for the block.
$35,000 for the whole set up.
1968-69 3946052 aluminum tall deck block with a date code on the backside of 06017.
Block is a standard bore 4.40 and has been pressure tested and is a good rebuildable core.
$8,000
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions.
Also can provide pictures as well.
Dennis Vugrinovich
