Old 01-13-2020, 09:41 PM
R68GTO R68GTO is offline
Default L78 Chevelle "signs"
Can someone give me a quick "what to look for" on a 69 Chevelle that might indicate it was an L78?
Old 01-14-2020, 12:20 AM
mockingbird812's Avatar
I’ll get it started.......None of the following are definitive but collectively will tell you if it is possible that it started life as an L78 Chevelle: 3/8” single fuel line (no return line), If engine is present: 3965272 cast block, 3919840 heads, 3933163 aluminum intake
Sam...
Old 01-14-2020, 12:52 AM
wheelhop wheelhop is offline
6 grand tach, deep groove pulleys, hi-po part numbers on distributor, alternator, holley carb if still there.
Old 01-14-2020, 01:17 AM
Sorry, should have provided a little more info. Engine is a vin-stamped L78 out of a Nova, but I will check all the hi-po bits on the engine anyway. Any specific rear end codes with L78 or were all ratios available? Assume disc brake was mandatory since it had to be an SS? How about the radiator?
Old 01-14-2020, 01:43 AM
3959164-GE list 4346 Holley for a 4 spd. 1100837 37A Alternator. Eaton “CV” fan clutch. “BO” is code for 4sd radiator. Believe the lowest numerical code was a 3.55 ratio.
Sam...
Old 01-14-2020, 01:54 AM
nova67 nova67 is offline
Default L78
3/8 single fuel line the 325 and 350 hp have dual fual lines
Old 01-14-2020, 02:26 AM
Yes, power disc brakes were part of the SS396 equipment.
Bill Pritchard
Old 01-14-2020, 04:56 PM
Isn't there something with the steering shaft?
Old 01-14-2020, 05:05 PM
That's Big Block specific,not L-78 specific.
Old 01-14-2020, 11:03 PM
Thanks all! I'll verify what's posted thus far and see if it still passes.
