Old 12-11-2019, 10:54 AM
chevyman0429's Avatar
Default 1969 chevelle ignition key help
My ignition key tumbler won’t stay in the steering column. It works as it should but pulls in and out with zero resistance. Is it something in the column causing this or is it the tumbler itself? Thanks
1969 SS 396 chevelle
1978 chevy shortbed step side
1983 chevy shortbed
1985 chevy shortbed
Attachments - The Supercar Registry tn_10014903.JPG 69B83833-864C-4844-96A0-26A5DE3B9B2A.jpeg 3B4B5547-9A44-4A2C-B528-04397C987765.jpeg 07A4595F-8C36-4B8C-8B6A-4BA72060B0D1.jpeg
Old 12-11-2019, 01:21 PM
Is it an OEM switch or aftermarket? There is a spring loaded tab on the back of the lock switch that holds it into the column. I have found on 'some' reproduction switches that this tab is not being held out far enough to catch and I had to rework the wire spring that puts tension on it to hold it out further.
Old 12-11-2019, 01:53 PM
Rick appears to be original but it was in the car when I bought it and the car has been restored previously from me owning it! Any way to tell
1983 chevy shortbed
1985 chevy shortbed
Old 12-11-2019, 02:11 PM
Pull it out and take a photo similar to what I did. If that tab is not sticking up a little reworking of the wire spring will keep the tab in the up position and it will hold. I will look at your photo and see if that appears to be the problem. If someone damaged the housing inside it could also cause this problem.
Old 12-11-2019, 03:03 PM
Rick it barely sticks up past the surface! If it’s in the lock position it will not go back in the column all the way.
1983 chevy shortbed
1985 chevy shortbed
Old 12-11-2019, 03:11 PM
It does in fact not appear to be sticking up enough. The front edge is beveled to allow it to slide in and lock when you insert it. Call me at 217-626-2277 and I will walk you through how I was able to fix that.
The Following 2 Users Say Thank You to SS427 For This Useful Post:
chevyman0429 (12-27-2019), Spooky (12-29-2019)
Old 12-27-2019, 01:13 AM
Rick your advice worked perfectly thank u Sir!
1983 chevy shortbed
1985 chevy shortbed
The Following User Says Thank You to chevyman0429 For This Useful Post:
SS427 (12-27-2019)
Old 12-27-2019, 01:51 AM
Great news and glad I was able to help.
Rick
The Following 3 Users Say Thank You to SS427 For This Useful Post:
mockingbird812 (12-27-2019), olredalert (12-27-2019), ZAPPER68 (12-28-2019)
