Old 12-08-2019, 03:44 PM
CC Rider's Avatar
CC Rider CC Rider is offline
Default Turbo 400 Case Connector Install
Is there a trick to installing these Turbo 400 case connectors? My original was replaced a month ago because it was severely leaking and loose. Bought another with an o-ring, dropped the pan, removed the old one which had a broken tab that I located, installed the new one and the pan, refilled the ATF, and all was good for about a month. The connector was tight, but now is somewhat loose and is leaking again.
Thinking about buying another connector and using a larger o-ring, or salvaging this one. Did I miss a step installing this one? BTW, the photo is upside down.
Thanks.
Rick
1966 Chevy Caprice 427-390
Attachments - The Supercar Registry 5445D5F7-6CBD-4F1B-903E-4B9CEC97DC51.jpeg
