Old 11-28-2019, 03:09 PM
dlv4540 dlv4540 is offline
Default 1970 L78 396-375HP Engine
1970 396 4 bolt block .030 over casting #3969854 dated H-20-9 with a CKO code for a 4 speed 375HP application. The vin number has a W so it is out of a nova but code was used in Chevelle and Camaro applications. The block has been cleaned, magged and pressure tested and has new cam bearings and freeze plugs installed. Block had small hairline crack in cylinders #5 & #7 so they were fitted with sleeves.
3964291 square port heads dated F-6-9 & F-18-9 cleaned and magged and will come with a factory replacement set of factory style valves with springs, retainers, studs and guide plates to reassemble.
6223 steel crankshaft turned .010 under and will need polished.
3870325 factory 8 inch balancer
High volume oil pump new
AC delco spark plugs R43 new in box
$3250 for the package and can ship if you cannot pick up. Also can be reached at 330-770-2517 for any questions.
Dennis Vugrinovich
Old 11-30-2019, 03:24 PM
Will offer free shipping anywhere in the USA. Also can ship to Canada.
Dennis Vugrinovich
