Old 11-10-2019, 10:45 PM
RALLY RALLY is offline
Default Chevy 396-427 used McLeod Steel Flywheel
Been cleaning out my inventory. I found a good used McLeod Steel Flywheel part number 46013C. Flywheel is a 30 lb 168 tooth part. According to the part number these can be used on both the SB/BB engine application. Light flash rust on the face should clean up well. Wheel has no grooves or bad wear from Clutch disc. 100.00 dollars plus shipping. Shipping cost with the weight of flywheel could vary. Send message and email address for pictures.
Old 11-10-2019, 10:55 PM
scuncio's Avatar
scuncio scuncio is offline
I may be interested if I can pick up - where are you located?
Old 11-11-2019, 12:29 PM
Message sent.
