Old 10-07-2019, 05:27 PM
JBALL JBALL is offline
Default Turn Signal Question
Folks,
Looking for some help with my turn signals.
Background:
1969 Camaro - Passenger side worked but drivers side would not flash. Started trouble shooting and wiring was a mess. All kinds of splices and some of the sockets were bad. Ground wire on drivers side was hanging on by a thread.
Step 1: Replaced the rear tail light harness along with both engine compartment harnesses. Still same issue. Drivers side would not blink. Would stay on solid. Passenger was fine.
Step 2: Replaced flasher under the dash by the radio. Both driver and passenger now flash, 4-ways, stop/tail all work! Everything works! kind of...
Now I have a different problem.
When I active the turn signal, the engine skips. Just while the cam is being selected. Once the lever is in place (signal on) no more miss.
I have no idea where to start. Ground? Steering column issue?
Hoping some one has experienced this and might have a solution. I can try posting a video if that would help. It almost stalls the engine.
Thanks SYC.
JBALL
COPO 9561 X-44 Fathom Green
