Old 09-25-2019, 07:04 PM
Edgemontvillage's Avatar
Edgemontvillage Edgemontvillage is offline
Default Wanted: Front Shock Absorber Mounting J-Nuts
Located, thanks SYC (and EM!). Need 4 original J-Nuts that clip onto the lower control arms for the front shocks. These are for my 1969 Camaro project however other 1969 F-bodies may use the same clips. Please PM if you have any available, thanks. (Rich P [Enoch] doesn't have any at present)
(photos from CRG)
Attachments - The Supercar Registry tn_010.JPG tn_008.JPG tn_007.JPG tn_006.JPG
Old 09-25-2019, 10:46 PM
galveston's Avatar
galveston galveston is offline
For your consideration Lloyd..... NO rust pitting ever, clean Arizona parts.
"Items in photos are smaller than they appear".
Shaun
The Following User Says Thank You to galveston For This Useful Post:
Xplantdad (09-26-2019)
Old 09-25-2019, 11:05 PM
PM Sent!
PS - nice photos.
Old 09-26-2019, 12:10 AM
enio45 enio45 is offline
shaun has sone nice hardware in his stash!
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 09-26-2019, 01:08 AM
Very nice set.
And for the record the Camaro IS an F body.
Guessing you meant A body or X body.
Old 09-26-2019, 01:31 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Very nice set.
Pretty sure he was referring to the "other" F body Lynn...The Firebird.
I ain't nobody, dork.
Old 09-26-2019, 02:42 PM
big gear head's Avatar
Just wondering, are all 4 of those from the same car? 2 with hex and 2 square.
Freddie
Old 09-26-2019, 03:03 PM
Correct.
Old 09-26-2019, 03:27 PM
X66 714's Avatar
X66 714 X66 714 is offline
They could've been. I recently spent quite a lot of time inspecting a 69 ss396 Camaro I had in my garage. The car had 11,998 actual miles. Never restored. Never wrecked. A true survivor. I will say hardware on one side of the car didn't match the other side.
I think you will see this car at MCACN in 2020.....Joe
The Following User Says Thank You to X66 714 For This Useful Post:
big gear head (09-26-2019)
Old 09-27-2019, 10:31 PM
Default Located!
Located, thanks SYC! Unfortunately Galveston (Shaun) wasn't able to part with the set pictured above but another Member stepped up with a set that's desert dry and very restorable.
